โAug-02-2017 10:18 AM
โAug-02-2017 05:23 PM
MrWizard wrote:
I once jumped started a car using a tow chain wrapped tight around the bumpers (his and mine) way back when cars had frame mounted steel bumpers
And one length of 10 guage wire
Because that was all that was available
But it's not what i would recommend
Forget 12ga
And forget alu unless it's 'one aught'
Get some good 2ga Copper for long cables
Or 4?6ga for normal lengthy cables
โAug-02-2017 12:08 PM
โAug-02-2017 12:02 PM
โAug-02-2017 11:54 AM
โAug-02-2017 11:50 AM
Chum lee wrote:
Look at the cables your vehicle manufacturer uses between the starter motor, the battery(ies), and the chassis ground. They use the connectors they do, the size/type cable that they do and they keep them short as possible for a very good reason. VOLTAGE DROP Starter motors are very thirsty when it comes to amps. Of course, you can't use OEM battery cable clamps on your jumper cables, that wouldn't be practical, but in general, keeping the cables as short as possible and as big (gauge) as possible will only help you when you or someone else needs a jump. Copper is king.
That withstanding, I've had very good luck using one of the many available portable "power station" type booster batteries. I bought mine at Costco for about $70.00. It saved my tail, and others, many times. I actually had my booster battery start a power stroke diesel with two dead batteries under the hood once. I couldn't believe it, but it did work. I just took about ten minutes to boost the dead batteries before starting. Keeping it fully charged all times is the key.
Chum lee
โAug-02-2017 11:00 AM
mike-s wrote:that's better, thanks.
he meant that the old ones were 16 ga X 8 conductor, or about 7 ga copper. And, he's thinking of making new ones, 12 ga X 10 conductor, or about 2 ga aluminum.
โAug-02-2017 10:59 AM
โAug-02-2017 10:53 AM
2oldman wrote:I think he meant that the old ones were 16 ga X 8 conductor, or about 7 ga copper. And, he's thinking of making new ones, 12 ga X 10 conductor, or about 2 ga aluminum.
#12 is pretty light for the kind of amperage that will be carrying. Cheap cables never worked for me. Sometimes the lengths you guys go to to save a few bucks is surprising.
โAug-02-2017 10:46 AM
โAug-02-2017 10:43 AM
โAug-02-2017 10:37 AM
โAug-02-2017 10:31 AM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
โAug-02-2017 10:28 AM
โAug-02-2017 10:26 AM
