Honda generator oil
snowpeke
What is the proper oil for my Honda 2000 ? Been running it for days in this PG&E shutdown
2002 Chevy DuraMax
2014 jayco eagle
Two Pekingese dogs
10 REPLIES 10
72cougarxr7
I have used the Amsoil small engine oil in all my generators for years.
If you need an off the shelf oil, walmart has rotella or delo 10w30 heavy duty engine oil that works well for small engine use.
Trackrig
I run the same oil as in my truck engine so I only have to buy and carry one oil. Rotella T6 5W-40 Synthetic. Has worked well for lots of hours and several years. I run it in seven different generators.
Bill
Cummins12V98
AMZ/OIL 15-40 Diesel Marine in all my gas engines. Non LE.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
snowpeke
Thanks for the tips guys!
2002 Chevy DuraMax
2014 jayco eagle
Two Pekingese dogs
firemedic1992
I only use Amsoil Small Engine synthetic in my Honda EU2000โ€™s
amxpress
I use this in my generator, and all my lawn equipment. Excellent stuff, especially when running my genny for 8 hours, stopping only to fuel. Your generator will thank you.
Amsoil 10W30 fully Synthetic small engine oil
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
Lwiddis
Honda is your best, official source for this information. Was it unavailable?
MFL
Nomad II
Nomad II
Honda power equipment 10-30
I use it in my Champ, hope it won't void my warranty!:)
Jerry
theoldwizard1
rockylarson wrote:
API-SJ SAE 10-30
This letter increments as newer oils come out. SN is the latest and exceed all previous levels.
Honda 2000 manual
rockylarson
API-SJ SAE 10-30
Honda 2000 manual
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
