โJun-26-2020 07:24 PM
โJul-01-2020 08:02 PM
theoldwizard1 wrote:I suspect it would kick both generators offline since the maximum output of both together is 33-1/3 amps.
I wonder what a 40A load would do ?
โJul-01-2020 06:32 PM
dieseltruckdriver wrote:
I built one of these using the factory Honda parallel cord and cut it in two and reconnected them at an rv 30 female plug. It works great, and is safe. I also think it cost more for me to do it than the one in this link.
โJun-28-2020 07:25 PM
opnspaces wrote:
Snip
and a link to a $30 unit.
Link
Another snip
โJun-28-2020 08:33 AM
โJun-28-2020 04:29 AM
โJun-27-2020 10:22 PM
Note that according this schematic there is NO CITRCUIT BTREAKER PROTECTING EITHER THE TWIST LOCK 30A OUTLET OR THE PARALLEL OPERATIONS OUTLET !
โJun-27-2020 10:20 PM
2oldman wrote:wnjj wrote:All you'll get? The generator is only rated at 13.2 a. Don't you get twice that max when paralleled.. otherwise what's the point?
The outlets are protected by a 20A breaker so thatโs all youโll get by paralleling 2 non-companion models.
โJun-27-2020 08:27 PM
โJun-27-2020 11:43 AM
2oldman wrote:
Yes OP, this is covered in the owner's manual and youtube.theoldwizard1 wrote:You don't have to question it if you google up the schematic.
I have to question the wiring BEHIND the outlet.
โJun-27-2020 10:40 AM
โJun-27-2020 10:30 AM
windinmyface2 wrote:
ps: why was it called a 'suicide' cord?
โJun-27-2020 10:26 AM
โJun-27-2020 10:25 AM
