โJun-23-2013 05:16 PM
โJun-28-2013 09:38 PM
โJun-28-2013 06:42 AM
Chinolbz wrote:
Question? Can't you make your own parallel cables with standard male cord end plugs? Yes the one end would be hot if you were not careful. But it would work, yes? Chino
โJun-27-2013 10:49 PM
โJun-27-2013 08:19 AM
Wayne Dohnal wrote:
I think the big mystery is why Honda Canada sells parallel capability for the eu1000, but not the eu2000.
โJun-26-2013 04:26 PM
โJun-26-2013 02:37 PM
โJun-26-2013 01:41 PM
There are at least 2 ways to interpret this statement:
"WARNING: Generators sold in Canada with CSA certification have the neutral bonded to the frame in compliance with CSA standards. Disconnecting the neutral bond will void the CSA certification of the generator."
โJun-26-2013 12:41 PM
robert@honda wrote:Wayne Dohnal wrote:It would be interesting if somebody with an eu2000kc2 (Canadian eu2000i) could look in the Owner's Manual to see if the statement about outlet testers showing an open ground is there, or better yet, report what an outlet tester plugged into the eu2000kc2 reports. I can't find the eu2000kc2 Owner's Manual online anywhere to look at it myself.
Not an RVer, but do not the Canadians require that the neutral be bonded? If so, one would not want the possibility of two different grounds to exist simultaneously.
Just thinking out loud.
I was able to connect with an engineer at Honda Canada. He tells me the Canadian version of the EU2000i is not, and has never been, neutral bonded. So, if tested with a typical household outlet testing device, it would correctly indicate an open ground, just like all USA model Honda generators, with the exception of EB-series models, which are neutral bonded to pass OSHA jobsite regulations.
-Robert@Honda
โJun-26-2013 11:19 AM
โJun-25-2013 04:04 PM
โJun-25-2013 12:41 PM
renoman69 wrote:
Thanks for explaining this Robert but you didn't answer why the Hondas are so hard to start when they are cold. Mine is a bear too when it is cold.
โJun-25-2013 06:48 AM
โJun-25-2013 06:35 AM
โJun-24-2013 06:54 PM
