May-11-2018 07:47 AM
May-11-2018 09:21 PM
May-11-2018 06:05 PM
May-11-2018 04:25 PM
May-11-2018 02:58 PM
May-11-2018 01:15 PM
johnsobc wrote:
Just electric..Correct......
ECO terminals are larger then T-stat terminals so BROWN wires will not FIT on ECO\Atwood only uses 140*F t-stat
When you pulled the RED wire off ECO were you just heating with electric, with propane or both?
From your description sounds like 'power track' on circuit board is shorted
NO ECO (RED WIRE removed)...NO Heating electric OR propane unless circuit board is bad
May-11-2018 10:57 AM
Correct......
May-11-2018 10:23 AM
May-11-2018 10:15 AM
johnsobc wrote:
I replaced one at a time to avoid confusion, but I believe the wire posts are different sizes and wouldn’t allow for this?dougrainer wrote:
1. Air pocket has no bearing on hot water
2. The standard tstat is either 130 or 140, depends on the year of the Atwood. EITHER tstat, you could NOT just shower on HOT only. You would be scalded. That points to a problem prior to this problem
3. Let it continue the heat cycle and see if the ECO trips and/or the pop off valve opens. No harm if it does
4. It is very easy to install a ECO in place of the tstat. That means the temp of the water could reach 180(ECO Temp trip). I would suspect you have installed the ECO instead of the correct tstat in the tstat mount. Doug
May-11-2018 10:07 AM
donn0128 wrote:
Then your upper limit switch is stuck closed.
May-11-2018 10:05 AM
Old-Biscuit wrote:
Atwood 6 gal...............?????
WHICH MODEL of Atwood 6 gal?
GC6a-10E uses on set of t-stat/eco for temp control
t-stat OPENS at 140*F (Closes at 110*F)
eco OPENS at 180*F (Closes at 150*F)----triggers FAULT Light and 'Locks Out' ALL heating
Atwood XT Model GE6EXT uses one set of t-stat/eco PLUS a mixing vlave
t-stat OPENS at 160*F (Closes 130*F)
MIXING Valve set for 130*F output......HOT HOT water is mixed with cold to maintain steady output
Standard model.....BOTH T-stat & ECO would have to FAIL CLOSED
XT Model....BOTH T-stat & ECO would have to FAIL CLOSED OR the Mixing Valve Cold INLET is not mixing with the HOT HOT out
To Test 'heating cycle' (either model) with water heater ON and heating ----remove a RED wire from ECO terminal....all heating should stop and fault light should come on
May-11-2018 09:04 AM
May-11-2018 08:37 AM
May-11-2018 08:30 AM
