My hot water heater has a small leak on the cold water intake side. It is a 10 gallon gas/electric atwood gc10a-2 hot water heater.
It is under the washer/dryer, which we have removed. The space is very narrow, only enough room to reach in with one hand. We replaced the fitting with one of the new style compression ones but it is still dripping. Iโm afraid to tighten in to much. Any ideas? My next thought was to remove the metal fitting that goes into the tank to see if it is damaged.
Does anyone know if this is a check valve? I have looked on line and some say that there are two check valves, others say there are none. Looking for an answer to that question. Thanks all.
2005 GB Cruise Air XL DP
3 slides, 350 Cat
2002 Ford Explorer, drag along
3 Standard Poodles 1 Mini Poodle
Vancouver Island BC, Canada
