sgt77 wrote:
I am looking at the advantages or disadvantages of replacing my two 12v house batteries with 6v.
Usually it's because it's harder to find good 12v that are true deep cycle. If you find one, it's either ultraheavy (my 6V weighs 66 pounds and a comparable 12V would weigh 132 pounds) or it's so small that you need to parallel it anyway and it's safer to put two 6 volts in series than two 12's in parallel. Finally, it's usually cheaper to buy 6 volt golf cart batteries, which are made and sold in larger quantities.
Some people even go with 2 volt deep cycles, when really large battery banks are being constructed.
My RV was designed for a single size 8D 12 volt - but I just couldn't handle that weight. To fit golf cart batteries, I needed more vertical room, and while adding that height, I was able to widen the compartment - allowing me to fit 4 sixers. It's worked really well for me.
In the Boonies!
