Houston Trailer Maintenance - Wasps & Mud Daubers??
CanuckCamper29
Good morning all.
I'm a Canadian that has moved to Houston this summer.
My house has wasp nests and mud dauber "nests" in many location.
I'm wondering what I should be doing for preventative maintenance on my trailer as I have a feeling the pests may find some spots that I don't want them to. Thoughts/advice welcome.
My typical Canadian fall routine has been to winterize the trailer! Not needed here!
Any other thoughts on what a regular trailer maintenance routine looks like in the South are welcome.
Thanks to all.
CC
2013 F150 Lariat SCREW
ProPride 3P
2013 Sunset Trail 29SS
3 REPLIES 3
fj12ryder
We screen anywhere a wasp can get into the fridge, water heater, or furnace. So far we've had no issues with them after 8 years.
Howard and Peggy
"Don't Panic"
naturist
Screen over the furnace exhaust, knock the nests down in water heater and fridge back panels, and run an ice pick up the fridgeโ€™s condensate drain.
donn0128
Lots of hornet and wasp sprays. I typically use three or 4 cans a year around the jouse. The key is constant checking and spraying. Around Houston I guess your only real worry is going to be the africianized bees
