โSep-14-2016 03:00 PM
โSep-18-2016 11:19 AM
โSep-18-2016 01:44 AM
ernie1 wrote:Packing the area between the two bearings will do a couple of things: It prevents less rust to form in the hub. It will allow grease to melt/flow that is not inside the bearing.
Mex,
Today I just put in new wheel bearings for my rv and always wondered whether one should pack grease in the hub area between the inner and outer bearings and also how much. I asked around and got a variety of answers but none really definitive. So, today I packed the heck out of the hubs and am hoping for the best. Are you saying it's not necessary, not a good idea or it doesn't make any difference with the new greases?
โSep-17-2016 09:16 PM
โSep-17-2016 11:51 AM
โSep-16-2016 08:47 PM
โSep-15-2016 04:43 PM
dougrainer wrote:
The Video shows REPLACING the Grease caps. WHO CARES if you Gorilla (dent/destroy) the olds ones OFF??????????????????????? You are replacing the caps. Now, if you are NOT replacing them, the Video is a good video. Doug
โSep-15-2016 02:34 PM
RVhiker wrote:
I put a medium sized slot screwdriver where the lip of the cap meets the axle and tap gently; the cap separates a bit and then the screwdriver can pry off the cap. I use a gently applied rubber mallet to tap the cap back on. My caps don't dent, and they last forever. Of course, dented they last forever, too.
โSep-15-2016 01:13 PM
โSep-15-2016 12:42 PM
โSep-15-2016 12:10 PM
โSep-15-2016 11:54 AM
โSep-15-2016 09:06 AM
Old-Biscuit wrote:
Channel locks to remove
Rubber mallet to install
โSep-15-2016 08:57 AM
โSep-15-2016 08:15 AM
