โFeb-18-2015 02:55 PM
โFeb-19-2015 02:54 PM
SaltiDawg wrote:
Oh, I understand the principle of hotel loads on a generator... including its own mechanical losses at low load.
That said, I believe the run time at 500 Watts will be much closer to the idealistic four days than your 16 hours.
However, my experience was on steam turbine generators, motor-generator battery/450Volt AC, and Diesel generators.... all operated in parallel. (
and occasionally A/C Shore Power.
Not much experience with small gasoline powered generators, so my intuition may be severely off, probably shouldn't have posted.
Be interested if the OP noted how much fuel he actually used overnight???
PS. Yes, I realize that my post would make the argument that were there no electrical load that it would run forever on a tankful. lol
โFeb-19-2015 02:26 PM
โFeb-19-2015 01:41 PM
SaltiDawg wrote:zackyboy3rs wrote:
It ran 12 hours last night. Thanks. Manual states put to 14 hours at 1/2 load.
1/2 load is 3500 Watts... your 500 watt load is 1/7 of that. Would seem your generator could run like 7 * 14 hrs = 98 hours or ~ four days on a tank of gasoline.
โFeb-19-2015 12:17 PM
โFeb-19-2015 12:03 PM
โFeb-19-2015 09:12 AM
greenrvgreen wrote:
If you run any gas generator underneath or near your trailer (as pictured), the fuel supply is unlikely to expire before the occupants do.
โFeb-19-2015 08:24 AM
โFeb-19-2015 05:09 AM
โFeb-19-2015 04:05 AM
โFeb-18-2015 05:59 PM
โFeb-18-2015 05:41 PM
โFeb-18-2015 05:16 PM
โFeb-18-2015 03:29 PM
โFeb-18-2015 03:23 PM
zackyboy3rs wrote:
2 250 watt heat lamp bulbs? 5.5-6 gallon gas tank. I am thinking 12 hours.
