โOct-18-2015 06:30 AM
โOct-18-2015 09:40 AM
โOct-18-2015 09:07 AM
Vintage465 wrote:That's very good performance.
If I spent the night somewhere and didn't plug in the voltage dropped to around 12.6-ish over night. "overnight" would have included the average careful usage of lights, and a C-Pap running all night w/o the humidifier.
โOct-18-2015 08:37 AM
โOct-18-2015 07:50 AM
โOct-18-2015 07:34 AM
BFL13 wrote:
Your two 6s seem to be working well.
โOct-18-2015 07:31 AM
RJsfishin wrote:
I think your voltages are not right.
A 12v battery is usually not over 12.8 volts after a 48 hr rest and no load.
And more in reality, a full charged non AGM will read more like 12.6-7
If you were reading 13v or more, you are still seeing the charging voltage
โOct-18-2015 07:13 AM
Vintage465 wrote:
So when I bought my new trailer it came with 300w of solar and a Samlex controller. When I first got the trailer home I installed one of the old 12v batteries from my old trailer and it regularly read 13.7 to 14.4v. Before leaving on my vacation I purchased two Interstate 6v batteries and wired them in series. This set up will read a maximum of 13.4(no load)when the sun is shining and the solar is charging. When the sun is gone the voltage is dropped to 12.9, maybe 13.0v. I didn't really get a chance to put them to the test as we were staying in RV parks most of the time. If I spent the night somewhere and didn't plug in the voltage dropped to around 12.6-ish over night. "overnight" would have included the average careful usage of lights, and a C-Pap running all night w/o the humidifier. So I guess my first question is: Is it normal for a pair of six volts to register a lower surface or peak voltage than a single 12v?
Thanks,
โOct-18-2015 07:11 AM
โOct-18-2015 07:08 AM
โOct-18-2015 06:38 AM
