Oct-13-2015 07:42 PM
Oct-18-2015 01:41 PM
Oct-18-2015 10:41 AM
Oct-18-2015 08:40 AM
Oct-15-2015 03:06 PM
Ductape wrote:
Hank, valid point if it is a four wire 240 supply. Maybe it's just semantics, but I would not call what you describe as reversed polarity. Of course with ac there is no polarity as such. Disregarding three phase rotation orders etc as out of scope.
Oct-15-2015 06:49 AM
Oct-15-2015 06:38 AM
Oct-15-2015 05:27 AM
Ductape wrote:
OK, I will bite.
IF the ground was open, as reported- then how was the allegedly reversed "polarity" determined?
Think about it.
Oct-15-2015 12:39 AM
WyoTraveler wrote:
Maybe that is why electrician was scratching his head.
Oct-14-2015 07:58 PM
MEXICOWANDERER wrote:
Three stabs and you're done. Has a white LED for checking when parking at night, audio tone, and vibrator alert. Will check 120, and 240 outlets any socket configuration.
Oct-14-2015 07:04 PM
Oct-14-2015 06:42 PM
Rbertalotto wrote:
What do folks recommend for Surge Guard protection......or are you simply reading the socket with a tester before you plug in?
Oct-14-2015 03:40 PM
Oct-14-2015 02:40 PM
Ozlander wrote:camperkilgore wrote:
Most of the time reverse polarity plugs present no problem.
Scenario #2: We're using an old trouble light, and the finger accidentally comes in contact with the outside of the metal socket that holds the light bulb in place. The socket is always connected to the neutral wire, so no big deal... unless the trouble light is plugged in to an outlet with reversed polarity. In this case, we'll get a shock. If this happens while we're laying on the garage floor working on a car, there's a good chance that this could be the last shock we ever get. This can also happen with old table lamps that have exposed metal sockets.
Old trouble lights and table lamps can be plugged in either way, so the polarity of the receptacle makes no difference.
Oct-14-2015 02:21 PM
