โMay-21-2022 06:10 PM
โMay-22-2022 09:24 PM
BFL13 wrote:
Please clarify your terminology. You likely have a "converter", not an "inverter/charger" . There is no such thing as a "charger inverter"
You likely have a single stage (13.7ish volts) Parallax 7300 converter in the 2006 Class C, or perhaps an Iota or PD or WFCO version of the same thing.
You can't meet the AGM battery charging specs with the plain version of one of those. You will need a charger that can do 14.4 volts and you will need an ammeter to measure when charging gets down to 1/2 an amp per 100AH of battery. The easiest way to do that is with a battery monitor that shows amps.
โMay-22-2022 12:52 PM
โMay-22-2022 12:29 PM
โMay-22-2022 12:00 PM
โMay-22-2022 11:57 AM
wpatters1229 wrote:
I have a 2006 class C four winds motorhome and want to start using AGM batteries. The charger inverter is the original one and I want to upgrade it to be able to charge the AGM batteries. Preferable a smart charger. Can I replace the current inverter charger in the same space or do I have to re-do that whole section that is currently under the side of the bed in the back of the rig?
โMay-22-2022 11:52 AM
time2roll wrote:
Inverter-charger should charge the AGM just fine with a change of settings.
If instead there is a far more common converter-charger it would be best to post the model number. Some are great, some adequate, some miserable. Some just need a plug in controller.
No the entire power distribution center does not need to be replaced.
โMay-22-2022 10:00 AM
โMay-21-2022 09:27 PM
โMay-21-2022 08:14 PM
