How to test auxiliary batteries for amperage?
bighatnohorse
I need a way to test a pair of six volt Trojan 105's wired in series and setting in my shop.
Has anyone a method of amp testing batteries that are on the bench?
I can't think of anything 12 volt that will pull a lot of current that is readily available to use as a test load.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
โ€œThe best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
17 REPLIES 17
donn0128
Just like testing a 12 volt battery. A giant resistor, a period of time to apply the load, and a way to read the voltage. Oh thats right, its called a load tester.
MEXICOWANDERER
Inverter load, starter motor engine disabled.
Wluldn't an accurate hydrometer reading work?
2oldman
Other than an inverter, I can't either.
