How to test power output of 30 amp
Damdifino
I want to test the power output of my 30 amp plug on my house to which I connect my RV. Which two of the three holes should I put the probes from a multimeter in?
2014 Arctic Fox 22H.
2009 Toyota Land Cruiser URJ200 Series
18 REPLIES 18
westernrvparkow
What information are you looking to find out? A multimeter can be used for multiple ways to achieve different results, hence the name.
azrving
SAR_Tracker
How to test an outlet....
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
2oldman
the blades. Since you had to ask, I'd also make sure the MM is set to read AC voltage.
