โOct-26-2015 10:07 PM
โOct-27-2015 08:20 AM
rcmiller32 wrote:
If your unit uses the AFT fluid you can change it out for full synthetic ATF fluid. It will flow better at colder temperatures. Might have to empty fill, run then empty and refill to swap most of the fluid out.
โOct-27-2015 08:17 AM
Pangaea Ron wrote:
Doug. . . I'll try to be more patient and plan ahead. I assume that I have 24,000 jacks on my W24 chassis and will expect 13 minutes when it's below freezing.
From the Manual: DO NOT ESTIMATE TIMES. USE SOME TYPE OF WATCH TO DETERMINE THE RETRACTION TIME OF THE JACKS.
Thanks everyone.
โOct-27-2015 08:03 AM
โOct-27-2015 07:16 AM
โOct-27-2015 07:12 AM
โOct-27-2015 05:06 AM
โOct-27-2015 04:38 AM
โOct-27-2015 04:35 AM
โOct-27-2015 02:20 AM
Porsche or Country Coach!
