hydraulic slider
bbaker2001
just purchased 2001 28 ft Cardinal.
Well opened up bed to check and clean. when we went to pull slide in, it almost fell in once it got 1/2 way in. the frame was not connected to floor or bed frame. not sure where it fastens to.. manual is no help.
it has 2 metal tubes that slide into another. much grinding noise.
what does the slide run on when going in or out.
I did put a 5 1/2 inch support for the center to keep it from falling in. this really helped, but what did it do before. looks like the bedframe screwed to floor, but they are gone.
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
6 REPLIES 6
bbaker2001
thanks, hope to get a little help even though 2001
BB from California
2015 Ram 3500
2001 Cardinal
Fulltimer50
oops
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
Chris_Bryant
You could look through the info at http://lci1.com/support-center
-- Chris Bryant
donn0128
Likely a Lippert slide mechanism. Tomorrow give Cardinal division a call and ask them. Be sure to have the VIN. I have found tech support to be very helpful on my Cedar Creek.
bbaker2001
cant take it back. how would I find out what model the slider is.
also, when It slides out the coach, is there something it slides on like roller, or just plastic bushing. I have corrected the tip in issue. it had snapped off the screws. I wish I could find a manual for it
BB from California
2015 Ram 3500
2001 Cardinal
donn0128
Kind of a confusing post. I think you would best served to find a mobile RV tech to come and fix it. At leadt enough to get it back to where you bought it.
