May-18-2014 09:46 AM
May-19-2014 01:25 PM
May-19-2014 01:02 PM
May-18-2014 10:40 PM
May-18-2014 04:36 PM
May-18-2014 02:59 PM
May-18-2014 02:18 PM
JimMartin wrote:
As far as removing the screw in the roof. That's not going to happen. New TPO roofing is all glue down.
I have unscrewed the wire were it goes into the fuse panel for now. There are only the four overhead double lights in the living area on this fuse. All the other ceiling lights in the RV are fine.
I decided to run a wire from the ceiling light in the hallway to the living area light. Going to try and do this by drilling thru the Styrofoam with a 24" long 3/8" drill bit, and then running a coat hanger thru it to feed the wires. Wish me luck!!
Do you think the fuse for the hallway ceiling light can handle 4 additional lights on it?
May-18-2014 01:33 PM
JimMartin wrote:Maybe I missed something: Removing the wire from the fuse removes the short from the fuse. But the short still exists in the wiring and will blow the fuse in the new circuit.
With the wire disconnected from the fuse panel it disconnects the bad wire, which will eliminate the short
May-18-2014 12:56 PM
put in LEDs if you are worried.
bumpy
May-18-2014 12:54 PM
I'd first try a 1/8" fiberglass wire puller.
As for the fuse - maybe.
But how does this eliminate the short?
May-18-2014 12:51 PM
May-18-2014 12:50 PM
May-18-2014 12:41 PM
May-18-2014 12:37 PM
