Identify plastic tank type
ajriding
How do I identify why type plastic I have on my tank?
The color is gray, it is a little flexible (not unusual for plastic).
The female threaded fitting is cracked, so I need to replace it soon. Im not sure of the best way to proceed either.
4 REPLIES 4
ajriding
Thanks, do you think there is a difference between the different polyethylenes? hard or soft?
I will order some welding sticks for polyethylene.
TechWriter
It's probably polyethylene. Here's a list of some manufacturers:
RONCO - one-piece linear polyethylene
TODD โ€” one-piece polyethylene. Marine tanks.
TRIONIC โ€” one-piece polyethylene.
ICON TECHNOLGIES (Camping World) โ€” ABS plastic
Ameri-Kart โ€” LDPE polyethylene and ABS.
D&M Plastics โ€” polyethylene
INCA Plastics Molding โ€” polymer resin
All-Rite โ€” polyethylene. Makes custom tanks for out-of-business RV companys.
Dura-Cast - polyethylene, Linear Medium Density (LMDPE)
Freeman Engineering - polyethylene
www.rvSeniorMoments.com
DISH TV for RVs
BFL13
Might be some info here or similar websites--just Google Rv tanks.
The potable water tanks were/are polystyrene (sp?)resin (white) that is quite flexible, while the older grey and black tanks were dark coloured ABS and much stiffer. It seems they now have a newer type grey and black tank from what these people say.
http://www.plastic-mart.com/category/33/rv-water-tanks
You can ask them your question about repairs or replacement I would think.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
northshore
my new to me Lance camper had a leak in the drain nipple on the gray water tank. I bought a plastic welder from Harbor freight. I never did figure out what type of plastic it was, however if you look on line (you tube) you can easily find vids on plastic welding, and I used the "bridge" method with the plastic welder. It worked out pretty darn good, I backed that up with JB weld for wet. I have filled the tank and its been sitting wet for about a week now and no sign of any kind of moisture. My guess is time will tell if this was good long term fix or not.
