Aug-12-2013 08:53 AM
Aug-16-2013 03:19 PM
j-d wrote:
For Doug, Yes, our Jayco Class C, with APU (you must've been in the Air Force!) has the RVP model with Start Relay.
For Chris, Your lookup indicate that Jayco had spec'd the Start Cap/Relay setup, which performs better than the PTCR type, and obviously better than no Start Kit at all.
OP, From another thread (Thanks, Jose!) here's a picture of an RVP/Coleman/Mach with Start Relay and Start Capacitor
Left to Right are Compressor Run Cap, Fan Run Cap, and Compressor Start Cap. Above Compressor Start Cap is the Start Relay.
SPP6E replaces Compressor Start Cap and Start Relay.
Not shown, but in place of Relay, is PTCR. SPP6 replaces Compressor Start Cap and PTCR.
Aug-16-2013 02:17 PM
Aug-16-2013 11:16 AM
Bluegrass Picker wrote:
I am very interested in installing a Supco SPP6 / SPP6E capacitor mod for easier starting of the AC. I currently have a Honda EU2000i (not the companion) and if at all possible I'd like to have the Honda run the AC with no other loads running. If not possible, then I'd still like to install the Supco if there could be a benefit at a later date when I'm able to acquire another EU2000i.
The question is, what Supco unit would I install in this unit, the SPP6 or the SPP6E, and would I remove the existing PTCR/Capacitor start kit? If so, how do I identify those existing components that will be replaced?
Aug-16-2013 10:44 AM
Aug-13-2013 10:10 AM
Aug-12-2013 07:27 PM
whs9841 wrote:
Doug, thanks for the info regarding the model number....that's good information.
I went back and found all of the documentation I received from my dealer. The model number on my documentation ends with 8564, which would indicate I don't have a hard start capacitor. I found the model number I provided in the original post on the applicances list on the inside of a cabinet door in the 5'er. I'm guessing the model listed on the appliances list in the trailer is incorrect, and the documentation that came with my 5'er is correct. (although you would think the model listed in the cabinet door of the trailer would be more accurate).
Aug-12-2013 03:44 PM
Aug-12-2013 02:50 PM
Aug-12-2013 02:21 PM
whs9841 wrote:
BTW, I'm assuming the SPP6E will hook up to the leads on the compressor run capacitor, just like the SPP6.
Aug-12-2013 12:17 PM
Aug-12-2013 12:09 PM
whs9841 wrote:
Chris, a few questions about your response:
1. If I piggyback the SPP6 on the larger capacitor, do I just connect the wires from the SPP6 to the two different posts on the larger capacitor?
2. Is there a way to wire the SPP6 as a compressor start capacitor for this a/c?
3. How would the SPP6E benefit me more in this scenario? How would it be hooked up to the A/C with the existing capacitors?
Aug-12-2013 11:32 AM
Aug-12-2013 11:28 AM
Aug-12-2013 11:21 AM
