Jun-08-2014 12:00 PM
Jun-16-2014 11:53 AM
Jun-15-2014 03:10 PM
Paul Clancy wrote:
was quite amazed. I'm not saying this will work for any ac in any condition but if you already own a 2400 yam don't assume it won't run your 15000 ac.
Jun-15-2014 09:33 AM
wwest wrote:like2rok wrote:
When i start it cold, then go to Eco Mode On, then RPM's are slightly higher than when it warms up and slows down even more. It IS Much Slower than Eco Off which wastes fuel overnight when the AC only needs to run a few minutes per hour. On this thread Please Refrain from suggesting the easy fix of Eco Off.
The entire purpose of spending $1000+ on this Inverter Generator is the Fuel Economy/quiet operation and I refuse to settle with Eco Off as a solution.
I will keep this thread updated on the attempts to modify eco idle speed or rejetting.
FYI I have the Whynter GREEN ARC-110WD AC with dual hoses that specs state 9.5amps maximum current
Simple. You need to add a TDR, Time Delay Relay, and a heavy electrical load (***)to your A/C.
The idea is that the relay delays providing power to the compressor for 2-3 seconds, initially providing a connection to the new "load". A/C switch "demands" cooling, the load comes on line, the genset revs up to speed, then the TDR switches the AC to the compressor.
*** 2 500W halogen bulbs.
An AC typically draws 3X the running load at compressor startup, maybe even 5X at times, high head pressure.
Jun-15-2014 09:27 AM
Jun-08-2014 03:10 PM
Jun-08-2014 02:52 PM
Jun-08-2014 02:44 PM
Jun-08-2014 02:20 PM
Jun-08-2014 12:47 PM
Jun-08-2014 12:27 PM
Jun-08-2014 12:13 PM
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
Jun-08-2014 12:03 PM
