interior lights
Bemota
I'm having an issue with myinside lights. They ramdomly go from dim to bright. I have a WFCO 55 amp charger, that goes from 14.3 to 13.2, on a 1 minute cycle. I'm on 50 amp shore power at a campground, my EMS tells me that I'm drawing 118-120 volts and about 10 amps on each leg. Other than the coach lights, furnace and etc. I have a 12V electric cooler in the basement for DW's insulin. I think the charger is going further south then I am, thinking about replacing it, should I go to a 65 amp or larger? This is a keystone cougar 2011 326MKS I got used last May. I have 2 12V batteries that run everything for over 4 hrs when I turn the converter off. Should I stay with WFCO ? Whats better, any help would be great. Thanks, Dan
Sorry for so long !!!
2017 Dodge Ram Big Horn 3500 HD Cummins
2018 Cedar Creek 34RL2
Navy CPO Retired, Jan (DW), and Ziggy (Cat)
18 REPLIES 18
Bobbo
Any auto parts store can load test batteries. Be sure the batteries are fully charged first, even if you have to put a stand alone battery charger on them.
Heck, if you were in TN, I would tell you to bring them to my house. I have a 500 amp carbon pile load tester.
Bobbo and Lin
Bemota
Thanks for the replies, I'm north of Oceanside ca. Where or who could load test batteries, I have to take a wall down to get to the converter to check it out. Thanks again, Dan
time2roll
Disconnect the battery and see if the voltage continues to fluctuate.
WFCO will run the Rv just fine with no battery... if it is working correctly.
Old-Biscuit
I have 2 12V batteries that run everything for over 4 hrs when I turn the converter off. .....:H
Two 12V should last 2 days.not 4 hours.
WFCOs are NOT the best but I would pull batteries and have them load tested first.
Lights getting bright then going dim and converter output fluctuating sounds like a converter going bad BUT could also be bad battery cell(s)
