Interior lights
TNMIMI1
I have the double light fixtures in my camper, a couple of them only work on 1 side is there something I need to do or check to make both sides work?
Also switch at entrance works porch light and entryway light the porch light is broken so I still need to remove it to see if this socket works but the entryway light both sides are not working.
Can someone please direct me on how to fix these issues
TIA
3 REPLIES 3
laurencen
my double lights have a switch that will turn on just one light or two, see if switch can move or like has been said exchange bulbs
1996 Kodiac camper, 1996 Dodge 2500 Diesel
1999 Fleetwood Discovery
opnspaces
Navigator II
Navigator II
Aside from switching the bulbs from good to bad check if the switch on the light fixture has multiple positions.
MNtundraRet
Navigator
Navigator
TIA
You did not give us much helpful information. How old is the camper?
Have you moved a good bulb to the other side of the fixture? If it works just replace the bulb. Clean the contacts of the fixture. Older bulbs can burn out. Especially outside.
Bulbs can be purchased at most gas-stations or auto parts stores. LED's use less current and are brighter.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
