Intermittent fan\ac
jeeperdude10
Last night I wanted to use fan only just for circulation and it would cycle, just like when ac is on. Is this normal? Thermostat issue or possibly campground electric hook up issue, we do get 115-120 volts at outdoor receptacle.
2016 Bounder 35K
2014 Freedom Edition JEEP Unlimited
Traveling thru this great country
4 REPLIES 4
Old-Biscuit
jeeperdude10 wrote:
Dometic electric t-stat and dometic 13,500 BTU ac unit. It is cooling okay but fan just stops intermittently when running on its on w/o AC cooling.
Works OK when in .auto. and running with A/C but when in ON fan runs intermittently??
Sounds like t-stat switch/contacts.
Is it an analog type t-stat........if it is replace with a digital
jeeperdude10
2016 Bounder 35K
Old-Biscuit
Has nothing to do with CG voltage
Thermostat....
Select fan ON and it should run until you turn it off
Could be issue with t-stat or run capacitor for fan
What A/C unit and which t-stat??
Joe417
You didn't specify what exact hardware you are using, but some models of fans have a thermostat built in.
The "fantastic fan" models that I have will cut on and off dependent on the temperature.
Joe and Evelyn
