โDec-23-2018 08:42 AM
โDec-28-2018 10:17 AM
โDec-28-2018 09:47 AM
โDec-28-2018 09:41 AM
โDec-28-2018 09:04 AM
road-runner wrote:I think the idea is that the converter could still be damaged even if the fuses open.
I'm also interested in further info about the converter being bad if the fuses are blown.
โDec-28-2018 08:54 AM
โDec-24-2018 09:37 AM
dougrainer wrote:
1. IF the reverse polarity fuses blow, the Converter will be bad. They do NOT protect from damaging the Converter from reverse polarity.
2. Do NOT replace with a WFCO if the Converter is a stand alone. ANY other brand will be better and more reliable. Doug
โDec-24-2018 09:26 AM
Bud
USAF Retired
Pace Arrow
โDec-24-2018 09:02 AM
โDec-24-2018 06:41 AM
โDec-23-2018 04:40 PM
โDec-23-2018 03:37 PM
โDec-23-2018 03:34 PM
โDec-23-2018 01:32 PM
Bud
USAF Retired
Pace Arrow
โDec-23-2018 12:33 PM
rjsurfer wrote:
Just looked at two fuses and they are good....and I'm getting 12.0 volts from the batteries.
Sure is looking like converter.
One thing, when I connect the battery the fan does come on for 10 seconds then stops. A clue?
โDec-23-2018 11:39 AM
time2roll wrote:ItsyRV wrote:9855 is a deck mount
Is your converter in a power center or is it a stand alone?
https://wfcoelectronics.com/product/wf-9855-55-amp/
For the OP: Yes a portable battery charger will get you through the trip. Get at least 10 amps rated. Maybe 5 if you are a light user.
For eventual replacement I recommend a PD9245 or PD9260
http://www.bestconverter.com/9200-Series-Deck-Mount
Operates much better than the WFCO.
