โJun-16-2020 07:36 PM
โJun-18-2020 08:17 PM
โJun-17-2020 09:18 PM
JRRNeiklot wrote:This would seem reasonably adequate for moderate use or intermittent max power.
The space under the bed is 6 feet long by 15 inches wide by 20 inches high. There is really no airflow under there, though.
โJun-17-2020 08:00 PM
dougrainer wrote:
So, the MAGNUM fans caused the problem? Since Magnum builds hundreds of thousands of Inverter's IF the magnum design was the problem, there would be lots of this type problem. FYI, Magnum was started by ex Heart/Xantrex Engineers and they designed and built a much better RV product. I have NEVER seen a Magnum have such a scorch fire problem and I have repaired/replaced probably in excess of 1 hundred Magnums in the past 15 years. Not all factory defects, usually outside 120 power source caused. Doug
โJun-17-2020 07:21 PM
โJun-17-2020 03:49 PM
pianotuna wrote:dougrainer wrote:pianotuna wrote:
dougrainer,
Using 120 volt fans may not be the best idea. My Magnum inverter caught on fire because of that design. Far better to have a 12 volt fan, thermostatically controlled, that will continue to operate when the inverter is turned off.
Explain how 120 volt 4 inch fans INSTALLED correctly could cause an Inverter to catch on fire. Doug
Properly install the inverter as per Magnum specifications, following their recommendations for clearances.
Put the inverter under a heavy load such as an air conditioner.
After 1 hour, decide you wish to go shopping.
So turn off the air conditioner.
Now turn off the inverter, using the remote control for the Magnum (internal fans cooling fans stop, as the circuit providing power to them is on the 120 volt side of the inverter).
Go shopping and come back to scorch marks up the wall above the inverter.
And that is how my Magnum 3000 inverter/charger self destructed.
If Magnum had chosen 12 volt fans, powered from the DC input, the scenario would not have occurred.
Magnum did replace it under warranty.
So, I suggest, 12 volt cooling fans, thermostatically controlled, may be a better choice.
โJun-17-2020 02:55 PM
โJun-17-2020 02:53 PM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โJun-17-2020 02:50 PM
โJun-17-2020 02:43 PM
dougrainer wrote:Itinerant1 wrote:
Plenty of folks have mounted the inverter under the bed with the lfp batteries, some have cut a hole in the side board of the bed frame to allow it to cycle cool/ warm air in depending on the season and add a small muffin fan. The inverters I've seen are 3000w ones not a small 1000w and not yet have I seen anyone say it killed the inverter.
Really, what do YOU do for a living? I WORK on RV's for a Living(41 years). My advice is based on what I have seen since Inverters have become common in the past 25 years. Also on the HEAT observed when Inverters are installed in a closed air space with lack of fresh air. Doug
โJun-17-2020 02:39 PM
dougrainer,
โJun-17-2020 02:11 PM
pianotuna wrote:
dougrainer,
โJun-17-2020 02:10 PM
โJun-17-2020 12:01 PM
โJun-17-2020 10:55 AM
