The inverter choice can matter for this testing exercise, but not for the real thing I think.
---I could not get the 12v battery supply to the rig cut off completely until I remembered that my 1000w inverter has something going on in it where the ground prong of its receptacles allows a path for the rig's 12v neg side to complete via the shore cable ground wire back to the power centre which is frame grounded. (I do not have this inverter chassis grounded to the rig frame either)
It is all about how your battery disconnect switch is mounted, pos or neg. Mine is on the neg, so the pos is still live and all it needs is a neg path somewhere.
In the real remote box scenario, the battery bank will not have a connection to the RV, so this shore cord path would not matter.
(Almot had this same model of inverter but returned it when he discovered this about it--I have had no problems in real life using this inverter for "whole house" since I have the 12v on anyway, so don't care about the extra path along the shore cord)
So I had to plug the shore cable into the 2000w inverter, which has a kind of GFCI receptacle set with what ISTR Wayne called "floating ground" Anyway that made the 12v go away, so the test could continue.
---The remote power supply is not quite like pedestal power because that has the bonded neutral. This raises the old chestnut about the requirement for that with an RV. Perhaps (without going into all that again in this thread please!) it is situational for the design and location of the remote set-up you would have, don't know.
(for testing like I did, it doesn't matter, since it is with all the same equipment in use already, however you have that arranged)
----I tried my 100amp PowerMax converter with the variable voltage unique feature, just plugged in but not with the DC output wires connected (will try that later)
It draws about 5amps on start up surge then quickly settles at about 2 amps steady at 13.7v. Changing the voltage up and down makes a minor diff in draw like 1.8a to 2.2a but need to do more tests. Anyway, that is half what the 7355 was reported at above but this is with nothing connected on the DC side. I will repeat the OP test later with the PowerMax instead of the 7355
Still hoping some will try theirs for this easy test and we can get comparable figures for other brands and sizes of converter.
---Another thing is your Trimetric or other monitor for the remote battery bank so you can see it in the Rv and in the case of the Trimetric, be able to push its buttons. You would not have the wire to the remote box most likely. Might be a wireless way to take care of that? No idea.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
