Nov-09-2019 07:29 PM
Nov-10-2019 07:52 AM
theoldwizard1 wrote:
IIRC, automotive fuses rating are based on a maximum of 32VDC-36VDC. Voltages above that may cause the fuse to blow (48VDC) the fuse to blow "early".
ktrmrfs is spot on with his statements. What people need to understand that the "variability" of a fuse. A 15A fuse will "carry" 16A of current for hours and not blow. It might even carry 20A for several seconds.
Back to the OP original concern. ATO/ATC sized inline fuses older with either 10AWG or 12AWG are readily available online. Although you can get these fuses up to 40A, If I needed a fuse larger than 30A I think i would use a Maxi-fuse. These typically come with 8AWG wire.
Nov-10-2019 07:38 AM
Nov-10-2019 07:31 AM
Nov-10-2019 06:01 AM
Nov-10-2019 05:39 AM
time2roll wrote:
You have more than two panels in parallel? What are the panel ratings? link?
If you are using MC4 why even have a combiner box? MC4 combiner is fine and you can get #8 MC4 down to the controller if you need it.
Otherwise yes any 12v fuse is fine.
Nov-10-2019 02:17 AM
Nov-09-2019 08:05 PM
Nov-09-2019 07:45 PM
