Jack solenoids
billseal
Does anyone know how to check the jack solenoids to see if they are faulty? I have been told to check solenoid for my front jack as it will not retract without pressure on it but I don't know how to do this. I have a 2005 HR Ambassador. Thanks
3 REPLIES 3
OnaQuest
If it will retract by prying it up with pressure, then it is NOT a solenoid problem. You need to run the jack down and then clean and oil the cylinder. You may have to do this more than once. The jack is raised by the springs only, once the solenoids are energized. If the solenoids were not working, you couldn't pry them up.
wolfe10
What make and model jacks do you have???????
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
1492
Moderator
Moderator
Moved from Forum Technical Support
