LCI levelers question
bass_n_bob
One of my LCI levelers lowers itself by about 6 inches after the motorhome sits for a day or two. As soon as I start the engine it does retract. I'm concerned that someday it won't retract and I'll be stuck somewhere. Any thoughts on a fix? THX
3 REPLIES 3
bass_n_bob
does not appear to be a leaking seal.
WyoTraveler
Leaking seal?
dougrainer
LCI levelors are a power down and a power up jack system. The fact that 1 extends with no power points to a leaking solenoid at the Pump assbly. It is a INTERNAL leak, not leaking on the ground. You go to the solenoid for that jack and make sure the manual release is set in normal position. But, if you have done nothing to the jack system at all and this came up, then the odds are you have a defective solenoid. Doug
