โJul-03-2021 08:26 AM
โJul-14-2021 09:42 AM
โJul-14-2021 09:22 AM
โJul-14-2021 08:25 AM
โJul-13-2021 10:19 AM
โJul-13-2021 09:11 AM
โJul-12-2021 06:50 PM
โJul-12-2021 08:55 AM
mdkelley wrote:
ordering a 20A/300W buck converter step-down unit. Hoping that unit is large enough I can just wire it in before my distribution fuse box and filter both the battery and converter for the entire camper (maxxfan, propane furnace, 3 LED lights, USB power outlet, and 12v/propane refrigerator). If not, I can use it for just the fan/light circuit and buy additional units for other circuits if needed, it was only $15.
on hold for well over an hour this morning with airxcel to see if they will warranty this (less than one year since purchase, just installed it a month or so ago). Had to drop off and opted for the callback feature on their phone system. I am wondering if they either have a very limited staff, or just so many issues their customer support department cannot keep up...
โJul-12-2021 08:31 AM
โJul-05-2021 02:38 PM
road-runner wrote:Gdetrailer wrote:Have to worry about getting rid of the heat from the diodes, too. Drop 1.5 volts drawing 4 amps and you've got a 6 watt heater. Maybe put the diodes in the air stream the way fan dropping resistors are cooled?
You will have to chose diodes that have a high enough current rating for the max draw of the fan.
โJul-05-2021 02:14 PM
mdkelley wrote:There are a lot of 12vdc voltage regulators on Amazon if you elect to go that route. Make sure you purchase one that can handle the appropriate current. I believe the MaxxAir fans draw approx. 3-4a (on high).
No wall switch, I wired it in directly and also tested it after installing and it worked fine. It just hasn't worked since installing the new high voltage converter and knowing the converter puts out higher voltage I did a web search about voltage and the MaxxFan. What I found was that there were some online who had issues with their fans burning out the circuit board, and MaxxAir told them their fan CB could handle somewhere around 13.6v but any more would fry the CB.
@otrfun - So, it sounds like maybe a voltage regulator would be a good idea between the converter and the camper (not between converter/charger and battery though) due to the higher voltage the single stage PD unit puts out?
I do disconnect the battery when running on shore power/converter because I agree with what you are saying about constantly subjecting the battery to the high voltage bulk charge (since I read on the BB site they say not to leave their battery subjected to the bulk rate for extended periods). I did a lot of reading up on the subject before finally deciding to go with a converter that the battery maker recommended. I am planning to only use this converter to charge the battery when it gets low. I am installing two battery monitors also, one to monitor discharge and one to monitor charge rate and levels. I am honestly brand new to LiFePO4 technology and there is so much conflicting info out there it gets confusing. Thank you all for the help and info.
โJul-05-2021 02:00 PM
BFL13 wrote:
Would a diode work with the direction choices? I figure the two wires to the fan motor get swapped for pos and neg with the rocker switch so the fan will either suck or blow.
โJul-05-2021 01:29 PM
โJul-05-2021 11:47 AM
โJul-05-2021 11:42 AM
mdkelley wrote:
From another forum
MaxxFan top voltage = 13.5V per Airxcel, Inc.
Once that fan gets to 13.5 is when its starts to cause concern.
Derek Hicks
Technical Assistance Coordinator
RV Products, a division of Airxcel, Inc.
3050 N. St. Francis
Wichita, Kansas 67219
Office: 316.832.4357
Fax: 316.832.3417
www.Airxcel.com
