Feb-04-2021 07:05 PM
Feb-06-2021 06:54 AM
Feb-06-2021 06:17 AM
Feb-06-2021 06:00 AM
BFL13 wrote:otrfun wrote:
OP here. Appreciate everybody's replies!
Really likin' the fact LifePo4's can accept full charge current for most of the charge cycle. I'm thinking our 45a converter will suffice with two 100ah LifePo4's for the time-being. If we can charge two 100ah LifePo4's from 10-20% to 90-95% in approx. 3 hours I think we'll be fine. That's approx. 150ah being placed back in the LifePo4's which is approx. double the ah we'd get into our two GC2's in 3 hours.
Looking forward to this LifePo4 upgrade!
150/45 = 3 hrs 20 minutes
45 x 3 = 135 AH
Best you can do with two GC2s is a 40-90 = 50% of C20, = 115 AH from a pair of 230 GC15s
that would be 40-80 at 45 = 92AH/45 = 2 hours, plus an hour to do the 80-90 with tapering amps =23 AH so :
115 AH takes 3 hours with a pair of GC2s
135 AH takes 3 hours with a pair of LFPs
BUT when you really want LFPs no matter what, you can call 135 twice 115 if you like. 🙂
Feb-06-2021 05:57 AM
Feb-06-2021 04:15 AM
Feb-05-2021 08:15 PM
Feb-05-2021 08:40 AM
theoldwizard1 wrote:
First, understand that LiFePO4 can be discharged much deeper, down to about 10% State of Charge. Therefore, it will take more energy to recharge them.
Second, depending on the brand of LiFePO4 batteies you buy, some do and some don't have built in charge controllers. Reality is, you are going to need a new charger to get optimal performance and life from your batteries.
The new "trend" is to buy individual cells (directly from China; up to 280Ah per cell) and build your one "battery pack". This will save you hundreds of $$$ ! For charging, use a MPPT solar charge controller and connect it to a "dumb" 15V-20V DC power supply.
Feb-05-2021 06:48 AM
otrfun wrote:
Assuming a pair of 100ah LifePo4's were discharged to say, 10-20%, roughly how long would it take a 45a converter to charge two 100ah LifePo4 batteries to 90-95% assuming the converter remained at 14.4v the entire time?
Feb-05-2021 06:15 AM
Feb-05-2021 03:35 AM
BFL13 wrote:RickLight wrote:
Different brands can charge and discharge at different rates.
My 3 Lion Energy UT1300 can each discharge at 150A and charge at 100A but prefer 45A. I upgraded my charger to a lithium rated one and went to 75A. Even at 45A it's just over 2 hours from 0 to full.
The beauty is that the charging rate doesn't slow down as they fill, like all lead acid based. Their "internal resistance" is much lower so the last 10% is as fast as the rest.
Those are 105 AH batts, so 3 x 105 = 315AH/75 amps = 4.2 hours
315/45 = 7 hours
So "even at 45A it's just over 2 hours from 0 to full"---where on Earth did you get that from?????????? 😞
EDIT-- 105/45 = 2.33 hours
Feb-05-2021 02:48 AM
Feb-04-2021 08:24 PM
Feb-04-2021 08:19 PM
Feb-04-2021 08:10 PM
Feb-04-2021 08:08 PM
