Feb-06-2015 12:43 PM
Feb-24-2021 02:45 AM
Feb-23-2021 04:09 PM
wa8yxm wrote:
So you know a switch rated for 120 or more volts AC (Standard house type switch) will have no problems with 12 volt DC. In fact it's kind of over kill. Cheaper but still over kill.
Feb-23-2021 02:29 PM
Feb-23-2021 06:23 AM
Feb-22-2021 03:44 PM
Jun-10-2017 02:04 PM
Feb-08-2015 12:46 PM
Feb-08-2015 06:38 AM
tenbear wrote:
You are right Bobbo, but we are talking about switching a meter, only a few milliamps at most. I don't think there will be much arcing.
Feb-08-2015 03:36 AM
Bobbo wrote:tenbear wrote:
I have used the AC switches on DC and they have worked just fine. I don't know what they do differently for a 12v DC switch but I haven't found it to matter.
It MAY work fine. It may not, at least for long.
DC arcs a lot longer and a lot hotter than AC when you break the connection. If the switch is not made for the longer/hotter arc, it can burn the contacts. You won't see the problem immediately, but it MAY lead to premature failure.
AC is 60 hertz, which means that the power stops completely 120 times a second as its direction reverses. That is why its arc is shorter, and therefore cooler. DC never stops until the switch completely breaks the contact, and that is not when the contacts separate. It is when the arc that occurs as the contacts are separating stops.
An example in my personal experience: This is not from AC vs DC but from using a switch on a circuit with higher voltage than it was rated for.
I had an electric fence around a garden pond to keep my dogs out of it. DW liked to work in her pond so I put a switch by the pond that broke the connection on the fence wire. It did not turn off the fence pulser. I originally had a switch rated for that voltage. Over time (outside in the weather) the switch finally broke. I went to a big box store and bought a cheap 120v/15amp light switch and wired that one in. Imagine DW's surprise the next time she went out, turned off that new switch, and touched the fence. The voltage was high enough to arc across the open contacts continuously. The voltage to the fence was NOT interrupted. She had words for me.
The same type of thing CAN happen with an AC rated switch on a DC circuit.
Feb-07-2015 07:27 PM
Feb-07-2015 06:04 PM
wnjj wrote:myredracer wrote:
If you have an independent RV repair shop nearby, I would take the switch there and they can possibly match it up out of a parts catalogue. Hallsville looks to be a small town so don't know if you have an RV shop nearby?
Maybe find a good electronics shop somewhere that sells all things to do with electronics. We have one here that is way better than a Radio Shack and carries a huge range of parts and components. You could possibly measure the switch and and send that to an electronics store like this along with some pics and maybe they can come up with something. It's very likely to be an industry standard dimension.
Another manufacturer of RV switches is American Technology.
Or... Just replace the entire light fixture c/w switch?
Or just buy the switch from Digikey online. It's only 85 or 98 cents, depending upon the color.
Feb-07-2015 11:21 AM
Feb-07-2015 05:23 AM
Feb-07-2015 05:00 AM
