I have used SSR's (usually crydom) for many projects, usually when I need minimal switching power IE a battery device switching something with it own power supply. Or optical isolation of the switch, or insanely high switch speed / durability.
For general switching in rv's I tend to use relays.
For exampleSSR's have a .5 to .75 volt drop across them, hence the need for a heatsink several times their size. At high loads, what you save on switching current, you loose on load voltage.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
