โApr-15-2020 12:29 PM
โMar-01-2021 07:26 AM
โMar-01-2021 05:46 AM
I will probably take some heat here but I dont like victron, I think they are way over priced and you are paying for the name. years ago they were the best but with the emergance of renogy and a couple others I dont think they are nessasary anymore. at that price anyways
โMar-01-2021 04:52 AM
Itinerant1 wrote:StirCrazy wrote:Itinerant1 wrote:StirCrazy wrote:Itinerant1 wrote:
Just a little update with no recorded data of the microair on the AC unit and the LFP batteries. Did a short move and dumped the tanks yesterday. Trailer was closed up for 3 hours and the inside temp was feeling warm at 82f (1600 hours). It was nice not having to hookup the generator for the air conditioner for a short cool down cycle. Ran the 15k AC unit for over an hour while setting up and winding down after the move till the inside colled down to 72f off the batteries. The sun was low in the sky so not alot of help from solar, when first turning it on it was drawing 60a, just before turning it off it was drawing 75a and used 11% of the batteries. No issues at running it from just the batteries with little assist from solar and will like it for brief cooldowns, maybe lunch breaks during a move that some cool air can be produced. The microair upgrade on the AC unit well worth it.
how big was your battery bank and solar again? would be nice to have the option of doing this in the 5th wheeh and since it needs more batteries anyways.....
Steve
500ah, 1,280w solar
hmm.. ok I am looking at going between 560 and 840AH in the 5th wheel, depending on if a buddy of mine wants to go in on some cells or not. I found a deal on 16 280Ah cells so 4 are going in the camper and 12 in the fith unless buddy wants 4 of them. but I only have 480 watts of solar up there... maybe its time for an upgrade. 4, 325w 24V pannels and a 60amp controler... would probabou need a larger wire from the combiner to the controler also.. now you have me thinking haha.
Steve
Living fulltime off the system now for almost 5 years if I were to do it over with what I know now and have experienced from it in daily conditions I would add 100ah more. The 1,280w of solar has been plenty during spring , summer, fall. In winter if I could tilt the panels that would make up any short comings in production and possibly eliminate the generator but I don't have a problem still living with full use of whatever I want in the trailer in a PSOC and if needed throw a little hold over charge with the Honda 2200.
My system is actually wired for 2 more panels but I figured to try 1,280w first and see how that worked I never added 2 more panels (360W) because it's been working perfectly with no complaints. Now if I was more in "hot" areas with no way of moving and needed to run the air conditioner from solar than I would add the 360w. 1,640w solar would carry the daily loads nicely. ๐
โMar-01-2021 04:49 AM
pianotuna wrote:
Steve,
You can keep the wire the same size if you go up in voltage. I'd suggest using an 100 amp controller for 1300 watts of solar, so it won't be working "full tilt" all the time (unless the battery bank is 24 volts, too). I find electronic devices tend to last longer when they are not "pushed to the edge" of their capacity.
I generally like the Victron products, but have heard rumors that they are not quite as responsive to questions as they once were.
โFeb-28-2021 12:47 PM
Steve
500ah, 1,280w solar
Steve
โFeb-28-2021 08:00 AM
โFeb-28-2021 07:52 AM
โFeb-28-2021 07:35 AM
Steve
500ah, 1,280w solar
โFeb-27-2021 08:09 AM
Steve
โFeb-27-2021 07:09 AM
โFeb-27-2021 07:06 AM
pianotuna wrote:01tundra wrote:pianotuna wrote:Freep wrote:pianotuna wrote:
Unfortunately I need -40. There is at least one LI chemistry that can do that--but nothing in a large format jar. Lithium titanate
Do you really need -40? Do you have no water in your rig, only ice?
-40 will kill Li batteries. I've boondocked at -37 c (-34 f). That temperature will also kill Li.
I've since found a battery chemistry called SiO2 which shares many of the attributes of Li. The differences that I'm aware of at weight (greater than a similar capacity lead acid) and the ability to be used and charged at -40. Some of the shared items are no sulphation, and zero maintenance. That means no more needing to get to 100% state of charge.
The SiO2 is about 1/2 the price of Li. It can "do" 900 amps for 5 seconds from a 100 amp jar, which I think is better than Li.
Cycle life is 2800 if you don't go below 50% soc, and 1500 if you go down to 20% soc.
Best of all, the SiO2 are sold in Canada. $600 ($450 usd) for 100 amp-hours. This is a competitive price with AGM.
Mount the batteries inside the trailer?
That won't help save LI when the RV is in storage.
โFeb-27-2021 07:04 AM
โFeb-25-2021 04:54 PM
pianotuna wrote:
3 tons I'll be in the same boat after the summer--batteries that outlive me.
โFeb-25-2021 03:21 PM
