Load Genset
kris_J
I want to run and load the generator with the cover on. I know I can't run the A/C but, what I want to do is load the gen with the microwave and maybe a coffee maker. Does anyone have any other ideas on how to load the gen with the MH covered? Thank you
2004 fleetwood 27'
7 REPLIES 7
MrWizard
Moderator
Moderator
You have the RV covered?
And you want to run the generator?
Is the space around the generator open?
Will it get airflow?
If the exhaust clear, or is it going to melt your cover?
While you are over heating the generator?
I can explain it to you.
1997 F53 Bounder 36s
Steeljag
Do you have access to an outside outlet to plug item(s) in ? It is recommended the generator be operated under load, for at least one hour, every month.
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
filrupmark
Hair dryer
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
Dutch_12078
GordonThree wrote:
Why can't you run the AC, isn't that the point of an on-board generator?
You shouldn't run the A/C's with the RV cover over them. Electric heater(s) are a better choice.
Dutch
2001 GBM Landau 34' Class A
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
eHoefler
Electric heaters
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Tom_M1
Water heater on electric. Toaster oven.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
