โJun-17-2014 07:47 AM
โJun-17-2014 06:48 PM
rjxj wrote:mena661 wrote:
I have the VEC1093 also and still on the original fan. It's a WAY better charger than any of the crappy converters. I'm kind of concerned that your SG hasn't risen past 1.250. IMO, you have some sulfation that you'll have to deal with after you get them charged up. Unfortunately, there's no charger you can get quickly (unless you over night something). I do recommend the VEC1093. The equalize function should get you back into the 1.275 or better range.
These are new batteries from samuels club a couple weeks ago. GC2's
โJun-17-2014 06:20 PM
โJun-17-2014 06:15 PM
โJun-17-2014 06:09 PM
โJun-17-2014 06:00 PM
BFL13 wrote:
Don't worry about the VEC1093DBD's fan. Mine was noisy. I opened it up and all it was, the fan was ticking on something where it was all in there in its little space. No effect on charger performance at all.
In the event, I took the fan out and re-mounted it externally using the same vent louvre it was behind but now is in front of. No noise. Same performance.
Those Schu's have weird charging profiles. Just get the 1093 and you will have the best there is. Many forum members have them and will swear by them.
โJun-17-2014 05:50 PM
โJun-17-2014 05:49 PM
westend wrote:
Whoa there, podner.:B
Before you make any big changes, you should know that your new 6V's are not going to be in a fully active state so the SG will be less for the first few cycles. You also started at a very significant discharge level. With 400+ amp hours available you may never see that DOD again.
Yes, 6 AWG is too small for the lengths involved. If you have enough #2 to wire from the converter to the battery, that would be a good choice. I think, with a wire upgrade, you could make this all work, no need for auxiliary chargers and such. Of course, a lot is dependent on your use.
โJun-17-2014 05:27 PM
โJun-17-2014 05:23 PM
โJun-17-2014 04:27 PM
CA Traveler wrote:but the seller said it would work even after explaining that I want to boondock and run only a generator and recharge as fast as possible.Madding isn't it? You use to be able to go to a store and get good advice but it's rare today. ๐
This is like the rig salesman - "And here you have this great battery and tank monitor (idiot light) to..."
It's all about selling and rarely about knowledge. :S
Today I went to a RV Truck Center to have them get a new Atwood stove top - I had the model number. He was 100% clueless about what I wanted and wanted to call Monaco... Probably if I wanted a Volvo truck part he could have helped...
โJun-17-2014 04:16 PM
โJun-17-2014 03:21 PM
โJun-17-2014 02:29 PM
โJun-17-2014 12:57 PM
rjxj wrote:BFL13 wrote:
You can use a 40a VEC1093DBD instead of buying a second converter that only does 14.x to use in that role. The 1093 will do 14.8 and also 15.7 for equalizing (which is also how to get the SG back to baseline)
No installation required! ๐
Next problem is your portable generator limit on how many converters it can run at the same time. The PD already is using a lot of VA.
The VEC1093DBD uses about 785 when doing its 40a. You can perhaps run it and the PD 55 together and get about 90a which is fairly good recharge time on four batts. If the gen won't do both with the VEC at 40a, run it at the 20a setting. That is still about 70a total charging.
I use various chargers all at the same time to get more amps and it works. With the VEC, get it going first , then turn on the converter. Sometimes it doesn't work the other way around.
I will consider the DB as its multi use instead of bolting in. I like the voltages you stated also. So I should be safe at 14.7 and separate the batteries from the house while equalizing at 15.7?
