loss power 96 Winnebago vectra gmc
base1957
Well...it's my year
Driving down the road...engine coughs once or twice and boom no engine, now brakes, no power steering.....will turn over but sounds like timing is off so bad it won't start at all...gotta get er towed.any thought s other than getting another rv...
5 REPLIES 5
ScottG
If the timing actually sounds like it's off then it likely skipped or broke the timing chain.
Fortunately not a huge job but in a MH it will be hard to get to.
enblethen
Borrow a code ready from O'Reilly auto parts or auto zone.
Sounds like a crankshaft or cam shaft position sensor.
Test it first
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
SidecarFlip
Not to be a bearer of bad news but I think GM used to use phenolic timing gear sets that were known to fail.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
base1957
Gbopp.yiu are right..just been a trying week with the rv..
gbopp
Let a mechanic check it before you hit the panic button. Maybe it's something relatively simple and inexpensive.
