low(er) wattage hot water heating elements?
a-d-s
The standard hot water heating element seems to be 1500W for small tanks. Does anyone know of lower wattage ones being available? Our trailer only has a 30 amp connection and I find in the hot summer with the AC on and the hot water cycling (and any other small loads) we trip the main sometimes. It's annoying and I am sure a smaller element would keep up to the modest demands just fine.
Not really a big deal, I am just curious.
2021 F-150 HDPP EcoBoost
2016 Coleman 262BH
Reese Dual Cam - 1200lb
13 REPLIES 13
dclark1946
smkettner wrote:
Half the voltage = half the amps. Resistance remains fairly constant.
Then do the volts x amps = watts. 25% is about right.
Or P=Vยฒr
Dick
Dick & Karen
Richardson,TX
2017 KZ Spree 263RKS
09 F250 V10
ScottG
Lynnmor wrote:
I plan on adding a 20 amp line in and use that for the water heater when available.
That's what I did and it makes all the difference!
Lynnmor
ScottG
I see my problem, besides doing it in my head, I was not deviding both values and maintaining the wrong constant.
It's been too long since I used this stuff I guess!
Thanks,
Scott
time2roll
ScottG
Chris Bryant wrote:
A 240 volt element will draw 1/4 of its rated wattage at 120 volts, so a 240 volt 2000 watt element would draw 500 watts, and a 240 volt 1500 watt element would draw under 400.
The math there has me stumped.
Wouldn't a 240V element run exactly half the wattage at half (120V) the voltage?
Or are they non-linear because of the resistance change do to heating of the element or something?
a-d-s
Thanks all. Good call on the 240v element, just ordered a 2000 watt one up off Amazon.
I could use propane, but it's nice when we're on full hookup for a couple weeks not to worry about propane.
2016 Coleman 262BH
wildtoad
The PO installed a Hot Rod kit on Atwood wh. Draws very little current, gets the water darn hot. I have no idea if the element will go into your wh.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
Iraqvet05
12thgenusa wrote:
Just a suggestion, run the WH on propane when using the AC.
x2
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
Chris_Bryant
-- Chris Bryant
greenrvgreen
When I bought a 6 gallon residential water heater at Lowes, it had a 1650w element. I searched Amazon and found a 1000w element that appeared to be a replacement for an RV wh. It fit my resi wh fine and I'm sure it would fit an RV wh.
Going from 1650w to 1000w, the hot water regen from cold went from 30min to 40 min--not even a notceable time difference.
time2roll
One of the conversion kits might be adaptable.
I think Hott Rod is just 450 watts.
http://dg-usa.com/hott-rod/
12thgenusa
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar, Victron BMV-712, Victron SmartSolar 100/30, 200AH LiP04 bank, ProWatt 2000.
