LP gas Leak Detector won't shut off
maznchle
Hi has anyone had a issue with their LP gas detector and how is it maintained etc. Mine went off at 10pm last night and i pressed the mute button and it stopped and a minute later came back on. I shut the gas off at the tank and opened the coach windows like the book said but it still continued to beep. The red light came on and not the orange(fault) and i put a fan in front of it and it stoped for the night. It came on again this morning so i disconnected it and took it appart and blew it out and ran a Q tip in and around it.I don't know if i should replace it as i have not hooked it back up yet.Paul..
9 REPLIES 9
fischer
I was thinking that if you you are plugged in , the converter should be putting 13.2v to your batteries. Check your converter before getting new batteries.
2016 Winnebago 35B v10
2006 Jeep Liberty 4x4
Blue ox Tow Bar
maznchle
Thanks for the help all. It was the battery sooooooo 299.00 plus and i am all set with new 6 volt batts. Intercity ??? had Trojan 105 in it but none close by and no time. RV learning is great. paul..
MEXICOWANDERER
Sure-Fire Fix
For malfunctioning detectors
1492
Moderator
Moderator
Moved from Forum Technical Support
maznchle
Thanks all, It does say in the product lit that it should not go below 8.5 so i will check 12 volt batt as i just filled them w/water a week ago? distilled. thanks for the info...paul
bfast54
Dick_B wrote:
Ours beeps on low battery voltage
X2.......................Make sure your 12 volt battery is up to snuff......................I found a bad 12 volt battery that way.....................:W
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
Dick_B
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
maznchle
Rig is a 05 = 8yrs maybe time? thanks..paul
rrupert
Over time they do go bad and must be replaced. How old is it?
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
