โApr-09-2016 05:15 PM
โApr-12-2016 06:22 AM
โApr-12-2016 02:51 AM
westend wrote:
Well done rookie, lol! ๐
This is a good example of how a meter can lead to a proper diagnosis. A meter should be in the toolbox of every RV owner, IMO. The problem is that folks that have never owned one are in fear of using one, the fear of the unknown. The reality is that learning the various functions of a meter is easy and it can lead to prompt diagnosis of failures in the two electrical systems of an RV. A meter is also useful to diagnose exterior light failures which are powered by the tow vehicle power.
There have been Forum member that have posted electrical problems and torn apart a whole furnace replacing parts as they go because they don't want to use a meter.
Glad to hear the fix was simple.
โApr-11-2016 11:40 PM
โApr-11-2016 11:17 PM
โApr-11-2016 09:58 PM
โApr-11-2016 03:04 PM
โApr-11-2016 02:32 PM
smkettner wrote:Undercover Poe wrote:
OP here. I had a few problems with my replies. I leave the battery on a concrete floor in heated basement and use a piece of 2" rigid insulation under it. I also had the battery on charge while trouble shooting the camper. Wouldn't that simulate a perfect battery?
Sure as long as voltage gets to the actual item or appliance.
Need 10.5 to 15.0 volts for RV stuff to operate.
โApr-11-2016 01:13 PM
โApr-11-2016 09:30 AM
โApr-11-2016 09:21 AM
โApr-11-2016 06:25 AM
Undercover Poe wrote:John&Joey wrote:Undercover Poe wrote:
... I assumed the battery isn't really full of life. It's probably old. Should I unplug from shore and try a new battery?
I always hate throwing money at something trying to fix an unknown problem. First I would take a look at the water level in the battery. I once had a rig where it boiled mostly away over the winter while I was plugged in. When I went to pull in the slides they did not work. I guess 13.2 off the converter wasn't enough after all without a good battery in the system.
So check the battery, top off if it's needed (Google it if you don't know the correct procedure,) then leave it plugged in to shore power overnight. Disconnect your battery and check it with the meter. Google volts for a battery and the charts will come up for state of charge. Wouldn't putting a charger on it simulate a prefect battery?
Your gas appliances have 12v gas safety features. If you have less then a certain voltage (I think it's 12.5v) the safety features will not allow them to run. So odd that all of your appliances won't work, your gas stove (that doesn't have 12v safety on it) does. So playing the odds, you need to figure out what they all have in common which is the battery.i did put a charger on the battery to simulate a perfect battery
Might not be it, but why make mountains out of mole hills in the beginning of troubleshooting.
โApr-11-2016 06:24 AM
โApr-11-2016 06:09 AM
โApr-11-2016 02:52 AM
