LTO batteries
pianotuna
Nomad III
Nomad III
Hi all,
It looks as if LTO batteries are becoming available.
I've written to the company below for pricing on a 100 amp-hour nominal 12 volt battery.
They can be charged at 10 C. (i.e. 1000 amps)
They work from -50 c (-58 f) to 60 C (140 f)
The cycle life is 30,000
Assuming a 100 amp-hour jar:
They can be drawn from at up to 10 C (1000 amps or 12000 watts)
They can be drawn continuously at 3C (300 amps or 3600 watts)
It seems to me that they would be a great choice where battery space is limited.
https://www.osnpower.com/12v100ah-lithuim-titanate-battery-lto-12v100ah-deep-cycle-life-12v100ah-lit...
from OSN POWER
Anyone know much about them?
https://www.osnpower.com/lto-batteries_c10
Regards, Don
17 REPLIES 17
3_tons
Per Stir Crazy, โ€œLFPโ€™s are now by far the cheapest option when you take into account usable AH and cycle life you can get 100AH LFP that test out good for about 400 bucks now, two ok deep cycles are say 320 (costco), but youโ€™re going to replace those costco batteries 4 times before you replace that LFP, more if you shallow discharge and run between 10 and 90% and so onโ€ฆ.โ€œ
Exactly, and LTO with HALF the power density (requires a doubling of battery count), what emerges is - itโ€™s easy to see why LFP will remain the dominant Lithium battery of choiceโ€ฆ
Ultimately (except for certain boutique usersโ€ฆ) I see LTO and SiO2 batteries as formats in search of a consumer marketโ€ฆ
3 tons
StirCrazy
Moderator
Moderator
pianotuna wrote:
Many folks here have done so. I like Li so long as they are not used in cold weather.
LTO are more expensive than LiFePo4 but can be used at both higher and lower temperatures.
Sio2 would be my choice as they are not fussy (i.e. no battery management system needed.
For my part I'd love to hear of someone with a similar use pattern to mine using LiFePo4 at -34 F as a "weekend warrior".
your probably not going to, your not even a "weekend warrior at -34, you do it for work. I don't think you'll find anyone who wakes up friday morning and says " look its -34 out, lets hook up and go to the campground"
I think your definition of " as long as there not used in cold weather" is a little flawed I had my camper out at the ski hill a couple weeks ago, it was cold -15C but my batteries prefored like it was summer. did I emjoy camping at that temp, nope but I managed to have fun as it was a school function for the kid and there were lots of parents there to have drinks around the bon fire with..
I don;t know about the price of LTO as I wants going to fill out there inquire now and be subjected to spam e-mail but as for working at a lower and higher temp theres not a lot of difference. the new ones I ordered can discharge to -30C so 10 degrees warmer than the LTO, and can discharge to +60C which I believe is 10 degrees higher than the LTO also. I can tell you at +60 I am not leaving the house so it doesnt matter anyways.
SiO2 is great for very low temps although they do lose up to 60% of there capacity at -20 compared to 20% for my LFP they can handle the ocasional run to 0 but your going to start losing cycles every time you do and not get that 1200 number. I can run to 0 every time and still get 3500. plus you have to limit your charging to under .25C which probably isnt a big deal if you have a big enough bank, with my AC charge and my solar both on I can only reach 0.2C on my bank so right there I am gaining cycles.
plus for me the biggest down side to SIO2 compared to LI is weight and size. LTO looks promising but for the extra 10 degrees on the bottom end I don;t know if they are worth it to many except you. the cycle life is kinda cool, but realy 10000 cycles, thats over 27 years of a cycles each day.. most would never realize that benifit and is it worth the extra cost for somthing that you won't use the features of anyways. LFP are now by far the cheepest option when you take into acount usable AH and cycle life you can get 100AH LFP that test out good for about 400 bucks now, two ok deep cycles are say 320 (costco)
but your going to replace thoes costco batteries 4 times before you replace that LFP, more if you shallow dischare and run between 10 and 90% and so on..
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
3_tons
PT says, โ€œFor my part I'd love to hear of someone with a similar use pattern to mine using LiFePo4 at -34 F as a "weekend warrior"โ€ฆ
Fair enough - your operating requirements are a somewhat unique situation (per past stated parametersโ€ฆ), and itโ€™s
great to know that the LTO option exist - but are most others to assume that LFPโ€™s temperature parameters are somehow insurmountable??
From my perspective, the opposite is true via either interior mounting, built-in heater circuitry or by using an aftermarket heating pad, and bear in mind that although charging needs to be avoided below 32d/f, still, LFPโ€™s are capable of discharging down to -04 d/f, and (for those unable to solve for low temps) consider that the extra (approx 100%, per case volume) power density helps to mitigate recharging until ambient conditions might improveโ€ฆJMHOโ€ฆ My solution (two 200a/hr LFPโ€™s) was to opt for interior mounting, without added optional heatersโ€ฆ
3 tons
pianotuna
Nomad III
Nomad III
ron4adams wrote:
I have been in correspondence with a sales rep at Dakota Lithium and they seem quite knowledgeable. I still haven't learned enough to know how much the conversion from lead acid to lithium would cost me but am considering it for both carriage batteries and engine battery. If anyone has already converted I would be interested in your experience.
Regards, Don
ron4adams
3_tons
โ€œthey are large compared to LFP per AH capacity, not much thoughโ€ - huh??
Slightly larger than the size of my single 200a/hr AIMS LFP, yet (at only 100a/hrsโ€ฆ) only HALF the amperage??
Added cost aside, suggest a huge difference in power density - they wonโ€™t be on my Xmas listโ€ฆ
3 tons
StirCrazy
Moderator
Moderator
pianotuna wrote:
vermilye wrote:
I'd also ask about the physical size of a 100 amp hour 12V battery. Since it appears that the energy density is close to 1/3 that of a standard lithium battery, it may be impracticably large.
Dimension: 281(H)*528(L)*240(W)mm
or
11" (H) 21" (L) 9.5 " (W)
they are large compared to LFP per AH capacity, not much though, the working twmp is -30C to 55C acording to there spec sheet no mention of charging, the working temp for LFP is -20 to 60C. the 20000 cycle life is rated at 0.2C the LFP I just ordered is 5000 at 0.5C my older ones were 3500 at 1C. at 0.2C and shallow discharge I imagin I can get 10000+ cycles if I live that long.. the only reason some one whould want one over a LFP is for the cold weather charging, but they don't even make mention of that on the page.. unless I missed it so is that still true , or was it theoretical in a lab?
that page is set up so bad you go buy one little section then they talking about LFP again when your on the LTIT page...
Steve
2016 Cougar 330RBK
3_tons
or
Note, Slightly larger than my Aims 200a/h LiFePo4, BUT only half the amp/hrsโ€ฆSize and cost aside, it might occur to many that it would less costly to drop off $50 bucks at Amazon on a 12v 25w silicon heating pad ($30), and a 12v digital programmable temp controller ($20)โ€ฆJMO
3 tons
pianotuna
Nomad III
Nomad III
or
Regards, Don
pianotuna
Nomad III
Nomad III
MEXICOWANDERER wrote:
Since they are rated to 10ยฐ F and use with "electric skateboards"
I would make sure they are "Thunder Proof"
-50 C; -58 F to 60 C; 140 F
Regards, Don
MEXICOWANDERER
vermilye
pianotuna wrote:
Hi all,
from OSN POWER
3_tons
FWIW, I came across this link:
https://climatebiz.com/lithium-titanate-batteries/
3 tons
time2roll
Some are not as specific but I think the primary use is for start batteries due to higher discharge rates and low temperatures.
But seems OK with deep cycling.
I am curious about how the start batteries and alternator work together.
