โOct-22-2015 07:12 PM
โOct-23-2015 07:22 PM
fluffo2 wrote:Those would work well for a bayonet socket. I'm planning on replacing the florescent tubes in a couple of fixtures so I would need a different solution. I most likely will attach them to the fixture and solder wires directly to the pins.
Tom, you may want to try these. 100% of the light can be directed through the lens.
http://www.ebay.com/itm/BA15S-to-G4-GU4-GU5-3-Low-Voltage-Adapter-for-LED-Pack-of-5-/151412491792?ha...
โOct-23-2015 02:12 PM
โOct-23-2015 01:04 PM
GordonThree wrote:I think you're confusing lumens with watts. Lumens is a measure of light. A 100 lumen bulb produces the same amount of light whether it's incandescent or LED but the incandescent uses many more watts doing it.
Keep in mind, hotwire bulbs emit their lumens in all directions, an isotropic light source. LED typically emit their lumens in the direction they are facing.
Hotwire bulbs installed in small fixtures spend a good majority of their lumens heating the fixture and less than half those lumens are actually lighting the inside of the RV.
โOct-23-2015 12:50 PM
โOct-23-2015 12:45 PM
โOct-23-2015 08:53 AM
โOct-23-2015 05:34 AM
โOct-23-2015 04:59 AM
โOct-23-2015 03:41 AM
โOct-22-2015 09:04 PM
โOct-22-2015 08:50 PM
Porsche or Country Coach!
โOct-22-2015 08:36 PM
โOct-22-2015 07:27 PM
