Lummins ?
Itchey_Feet
Looking @ replacing reading lights over bed, now has 11391F bulbs in them, will there be enough light to read by if I install 5050168 LED bulbs rated @ 160 Lummins. Thanks in advance.
My feet are fine as long as they are traveling.
13 REPLIES 13
Tom_M1
fluffo2 wrote:
Tom, you may want to try these. 100% of the light can be directed through the lens.
http://www.ebay.com/itm/BA15S-to-G4-GU4-GU5-3-Low-Voltage-Adapter-for-LED-Pack-of-5-/151412491792?ha...
Those would work well for a bayonet socket. I'm planning on replacing the florescent tubes in a couple of fixtures so I would need a different solution. I most likely will attach them to the fixture and solder wires directly to the pins.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
fluffo2
http://www.ebay.com/itm/BA15S-to-G4-GU4-GU5-3-Low-Voltage-Adapter-for-LED-Pack-of-5-/151412491792?hash=item2340e34610:g:vhAAAOSwDk5UF9o4
Tom_M1
GordonThree wrote:
Keep in mind, hotwire bulbs emit their lumens in all directions, an isotropic light source. LED typically emit their lumens in the direction they are facing.
Hotwire bulbs installed in small fixtures spend a good majority of their lumens heating the fixture and less than half those lumens are actually lighting the inside of the RV.
I think you're confusing lumens with watts. Lumens is a measure of light. A 100 lumen bulb produces the same amount of light whether it's incandescent or LED but the incandescent uses many more watts doing it.
Tom
2005 Born Free 24RB
Minneapolis, MN
mkirsch
Nomad II
Nomad II
INDIVIDUAL LED's emit light in the direction they're pointing.
If you get LED conversion bulbs as pictured above, you will notice that the LEDs are arranged around a central cylinder so the end result is that the light is emitted in all directions.
End result is disappointment. It will be nowhere near as bright as the incandescent.
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
2oldman
beemerphile1
I had to look to see what "Lummins" was. :B
I believe your lamps are 'IF' (inside frost), not '1F'.
A 1139IF lamp is 190 lumen, 160lm will be dimmer.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Tom_M1
I just purchased some LEDs on eBay. They are about 500 lumens. I bought 10 of them for $16.19 plus $2.59 shipping. They have a built in regulator so they will handle a wide range of voltages. I have not used any yet so I don't know if interference will be an issue. They don't come with any adapters so you would either have to modify the bulb or the fixture.
Cheap LEDs on eBay
Tom
2005 Born Free 24RB
Minneapolis, MN
Ivylog
Took a while to figure out your numbers... a 11391F is the same as a 1156 base. Your 5050168 LED is a over priced tail light bulb. 168 lumens is going to be borderline if it is not focused. When I search Ebay for 1156 led I get 20,000 hits. If the light fixture is in the right position, a spot light like this may be the answer. While something like this may be too much lite, it gives you a better idea what's available for $3.
Upgraded with a 08 HR Navigator 45โ€™...
MEXICOWANDERER
My poor eyesight loves the 3000 lumens over my headboard. Not a typo, Three followed by three zeros - 30 actual watts. Enough to light up the whole room. But this might serve to show lumens quantity is subjective. Tough to plan. Start somewhere then add more light if needed.
Golden_HVAC
If you have the ability to put in a pair of light bulbs, it might be plenty of light.
For my bathroom, I took out the socket that holds the old lamp, and wired in two panels in each side of my twin pack light fixture. The panels that I used are 24 LED 5050 LED lights, with 4 of them on, I have more light than before, and it only draws 0.4 amps at 12 volts.
Good luck,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
rexlion
Considering the location 160 lumens should be enough, although you probably will notice that it's a bit less bright than the incandescent.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
fla-gypsy
A 60w incandescent produces about 800 lumens. You will have to decide if it works for you.
