โNov-20-2016 10:28 PM
โNov-22-2016 04:15 PM
โNov-21-2016 12:50 PM
JimInMich wrote:saw that one too. If you are outside of that range you're in trouble anyway and at least you can see it, but you'll probably hear it first. The nice thing about an analog meter is you can watch hunting (if it occurs) way better than a digital meter, but again you will hear it.SCVJeff wrote:
Since you are building a panel, THIS will do nicely. And there are cheaper ones down the page.
That one does cover a larger range. THIS is the one I was looking at.
โNov-21-2016 12:41 PM
MEXICOWANDERER wrote:
Yes and would love a link please...
pianotuna wrote:
Hi Jim,
A kill-a-watt meter can monitor frequency. It is a best bang for the buck and is plug and play.
scrubjaysnest wrote:
Trimetric or similar for monitoring the batteries is the best thing. It can be wired to monitor house batteries with a cranking battery voltage input or switch the second input between solar panels and cranking battery.
Correct analog resolution is much preferred to digital because speed hunting vs digital sample rates causes unreadable values. From the school of hard knocks.
โNov-21-2016 12:24 PM
โNov-21-2016 12:18 PM
โNov-21-2016 09:45 AM
RLS7201 wrote:MrWizard wrote:
You mean 'meter'
Governor is on the generator motor/throttle
Good Governor Meter
Richard
โNov-21-2016 09:30 AM
โNov-21-2016 08:08 AM
โNov-21-2016 07:42 AM
MrWizard wrote:
You mean 'meter'
โNov-21-2016 07:29 AM
โNov-21-2016 06:30 AM
โNov-21-2016 05:12 AM
โNov-21-2016 03:42 AM
โNov-21-2016 02:18 AM
