Sep-25-2010 03:17 PM
Jan-23-2017 07:38 PM
Almot wrote:It's been awhile since I compared larger RV solar systems. So here is todays comparison:
Yes, lower cost of PWM is TAD offset by the number=cost of panels and a bit more wiring pains. What annoys me is that PWM are not as "automated" as MPPT.
Jan-23-2017 05:20 PM
Jan-23-2017 05:05 PM
CA Traveler wrote:
no brainer choice. ie The MPPT controller cost vs the lower PWM cost was offset by more and smaller 12V panels and installation. Parts cost only was considered. About 500W was the crossover point.
CA Traveler wrote:
What about MS PWM controllers? No personal experience, just curious.
Jan-23-2017 03:52 PM
Jan-23-2017 03:27 PM
Jan-23-2017 03:15 PM
Almot wrote:What about MS PWM controllers? No personal experience, just curious.
Don - not "all", but "all this" - meaning things mentioned in the BFL13 post. Shorten the Vabs stage when necessary, adding amps in the Float stage when demand increases. My Rogue MPPT does this. MS MPPT 45, 60 (and 30?) do this. Probably some others too.
Jan-23-2017 01:19 PM
Jan-23-2017 12:12 PM
Jan-23-2017 12:04 PM
Jan-23-2017 12:01 PM
Almot wrote:
...or you can get a controller that will do all this for you. Grape doesn't.
Jan-23-2017 11:59 AM
BFL13 wrote:
Some days you want a shorter Vabs time if the batts are bubbling too much, and other days you can't get enough with all the clouds. You have to pay attention every day what is going on with the batteries and how to play the solar settings.
Jan-23-2017 09:56 AM
Jan-23-2017 06:08 AM
brulaz wrote:
Never thought elevated voltages (upto 14.8V Vabs) to be much of a problem as long as you watch the water in the batts.
Our MPPT can stay in Abs and over 14V for long periods when we're using much electricity during the day. Also it's easy to force into mppt mode, which I'll often do late in the day to get batteries as full as possible before night fall.
Jan-23-2017 05:04 AM
Almot wrote:BFL13 wrote:
If the controller drops to Float voltage before you want it to, it is very frustrating trying to get it back to Bulk, since the batts have to get down to 13.2 (eg) which can take a long time.
Yes, it would have to go through Absorb again.
No, it won't take a long time if controller is smart enough to shorten the Abs stage accordingly to the current and/or voltage at the beginning of this "new" Abs stage. Those cost more than Grape though.BFL13 wrote:
If you can program Float to be near the same higher voltage as Bulk, then you are good all day.
Why keeping batteries all day at elevated voltages is good?
Jan-23-2017 03:57 AM
