motorhome leveling
Todd757
Every time we level our Discovery 40x using the auto mode it is right side low, not much but low. About 1/4 bubble. We put a level on the floor. Can the "calibration" of the leveling system go out of wack? If so, can it be recalibrated?
Also, our motorhome sits right side low on level ground. Could there be a problem with the air suspension?
Thanks.
7 REPLIES 7
MEXICOWANDERER
And thanks from me. When my back screams in pain, and I run out of breath running back and forth from plastic wedges to steering wheel to bubble, I can read stories like this and maybe just maybe a placebo effect takes place and my back hurts less. Meant to make you smile... ๐Ÿ™‚
Todd757
Thanks everybody. I live about 45 minutes from wildwood. I will call them when I get home. Again, thanks
sdianel_-acct_c
Our 2004 Country Coach did the same thing. It was a ride height valve. Alliance Coach in Wildwood fixed it quickly. There is also a dump valve that could be staying open. These valves start sticking over time. We have now replaced all of ours. If you are traveling you can take also it to the HWH factory in Iowa. There is a wait there right now so I would make an appointment.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
CA_Traveler
Sounds like your ride height has problems and that needs to be fixed first. Could be adjustment or air valve or other issue. Then address the leveling if it's still a problem.
Correct ride height can be very important and can effect proper rig handling and drive shaft alignment.
2014 Grand Cherokee Overland
Bob
lj2654
Yes, the ride height can be adjusted but must be done on a level flat floor at a garage. Air leveling can be recalibrated by following the manual for your particular leveling system.
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
Dick_A
Moved to Tech Issues from Technical support forum
2009 Tiffin 43QBP Allegro Bus
RoadMaster Sterling Tow Bar
US Gear UTB
Ford Explorer Sport Toad
WA7MXP
"Pisqually" the attack kitty :B
Rollnhome
There is a process for resetting the leveling. It is in the levelers owners manual. If you do not have the manual you can find it on line.
As for the ride level it is best if you take it to Freightliner and have them check and set the ride height, a fairly simple adjustment.
2008 Discovery 40X towing a Jeep Grand Cherokee
