โMay-11-2018 12:38 PM
โMay-12-2018 11:27 AM
โMay-12-2018 11:07 AM
BFL13 wrote:
"One exception is portable panels with a long run, (100ft+) then series panels with MPPT will reduce IR loss"
Depends. You then have lower controller efficiency by going 24-12 instead of 12-12. If the efficiency difference is 3%, that counters a lot of wire loss.
โMay-12-2018 09:04 AM
โMay-12-2018 09:00 AM
โMay-12-2018 08:38 AM
โMay-12-2018 04:59 AM
โMay-12-2018 04:06 AM
MrWizard wrote:
i'll get some screen captures from my tablet running the APP
โMay-11-2018 09:06 PM
โMay-11-2018 04:46 PM
โMay-11-2018 04:39 PM
pianotuna wrote:
Hi Time2roll,
The Morningstar MPPT 60 does have some advantages--it is essentially three controllers "stacked" together, so it is more efficient at low amperage than the 45.
I made the mistake of only getting a 30 amp controller, that meant upgrading meant buying either an additional controller--or buying a larger one. I've not done either because of the cost.
โMay-11-2018 04:29 PM
โMay-11-2018 04:14 PM
โMay-11-2018 03:38 PM
time2roll wrote:pianotuna wrote:I also recommend a controller that automatically adjusts absorption time based on charge level.
Minimum standard for the controller would have adjustable voltage set points and a temperature probe on the battery bank.
โMay-11-2018 02:41 PM
