โJan-11-2015 06:51 AM
โJan-14-2015 03:26 PM
โJan-14-2015 02:25 PM
โJan-14-2015 10:28 AM
jrnymn7 wrote:Those are bypass diodes and serve no purpose for 12V panels in parallel. Not to be confused with blocking diodes which prevent a panel from draining the battery at night.
Re; diodes, I thought that's what's inside the little black box?
โJan-14-2015 10:12 AM
jrnymn7 wrote:
but in a pinch, say if one's controller crapped out, couldn't you just use a direct connection?
โJan-14-2015 10:04 AM
โJan-14-2015 09:19 AM
jrnymn7 wrote:
Seems to me, if using 12v panels, if all you ever did was bulk charging, you wouldn't need a controller at all. And if you were to de-rate the 12v panels to max out at say 14.8v, you could abs charge without a controller, as well?
โJan-14-2015 08:43 AM
โJan-14-2015 08:34 AM
And yes, I do realize at times there would be insufficient voltage available for charging, but in a pinch, say if one's controller crapped out, couldn't you just use a direct connection?
โJan-14-2015 08:33 AM
โJan-14-2015 08:18 AM
Salvo wrote:
Your confusion stems from the fact that solar panels are not voltage sources but current sources. In bulk mode, the panel is directly connected to the battery. The panel voltage is equal to battery voltage. As battery voltage rises, so does the panel voltage. When the battery voltage reaches the absorption set point, pwm action begins.
When using a pwm charge controller, panel voltage is never at 17V. Panel voltage has two states, either Vbat or Voc (panel open circuit voltage).
โJan-14-2015 08:12 AM
โJan-14-2015 07:24 AM
MrWizard wrote:
you seem to be under the assumption that panel output is 14v instead of 17v ?
and doesn't get altered and processed to become 14+ charging volts
try measuring the panel voltage at the input of the controller
โJan-14-2015 06:34 AM
โJan-13-2015 05:59 PM
BFL13 wrote:MrWizard wrote:
Well I give in and will drop the debate
The proffered explanations, do not match the true definition of PWM
So mfg have borrowed and corrupted the terminology
Yes, salesmen vs engineers again. ISTR the usual sort of bulk converter also has some variety of PWM to hold its output voltage constant. It can get very frustrating tying to follow all this!
โJan-13-2015 05:38 PM
a shunt controller goes on off
a PWM controller "modulates" the voltage
i know you don't believe me , you think i'm wrong
test equipment will tell the truth either way
