โJan-11-2015 06:51 AM
โJan-30-2015 04:19 PM
JiminDenver wrote:
That is because you are only applying a dollar symbol and not looking for the best tool for the job. The only time dollars should be a consideration is if you look at it and either would fill the need. That's when you look at the advantages and cost of each.
โJan-30-2015 03:11 PM
โJan-30-2015 02:01 PM
BFL13 wrote:brulaz wrote:BFL13 wrote:
I almost understood that part just above, where the buck converter tries to balance the power at its input with the power being used at its output. It has to find a voltage at the input that will get the power down to what is being used at the output.
Suspect that it is the buck converter as directed by the microprocessor that is doing this. Not the buck converter by itself.
Well my little buck converter gizmo by itself was hopeless. It got saturated and all that. Then I was told here it needed a bunch of other circuits stuck on so it would behave properly.
โJan-30-2015 01:57 PM
โJan-30-2015 01:53 PM
โJan-30-2015 01:48 PM
โJan-30-2015 01:42 PM
โJan-30-2015 01:10 PM
jrnymn7 wrote:They don't do just one or the other. On the IV curves the maximum power occurs at less than the maximum amps but with more voltage. MPPT is looking for the maximum power which is watts. And that maximum power is for the input to the controller. Then the controller converts that power on the output side (more amps and less voltage) for maximum power that the battery will accept.
We know MPPT controllers use excess voltage to create amps. But do they also use available amperage to create voltage?
โJan-30-2015 12:31 PM
โJan-30-2015 12:29 PM
โJan-30-2015 12:25 PM
โJan-30-2015 11:59 AM
โJan-30-2015 11:48 AM
BFL13 wrote:
That is what I was asking earlier with questioning the panel voltage once no longer at Vmp. Answer was panel voltage goes up higher than Vmp so input and output power is less and so output amps is lower at that Vbatt. But if there is a load greater than battery charging, panel voltage goes down (back up the knee on the IV curve) allowing output amps to go up. (I never quite understood how that panel voltage change happens)
Wikipedia "Maximum Power point tracking" wrote:
When the batteries in an off-grid system are fully charged and PV production exceeds local loads, an MPPT can no longer operate the panel at its maximum power point as the excess power has no load to absorb it. The MPPT must then shift the PV panel operating point away from the peak power point until production exactly matches demand.
Wikipedia "Buck Converter" wrote:
A buck converter can be used to maximize the power transfer through the use of impedance matching. An application of this is in a "maximum power point tracker" commonly used in photovoltaic systems.
โJan-30-2015 11:47 AM
jrnymn7 wrote:
RE; Panel Wiring and MPPT:
Correct me if I'm wrong,
(snip)
Assuming ideal conditions, and using two 140w panels with specs of 7.9a Imp, 17.7v Vmp, and 8.2 Isc, and using a Vabs Setpoint of 14.8v:
(snip)
If wired in series:
While in mppt mode, bulk charging at an average of say 14v, average current would be 20a (280w / 14v)... Same as with parallel wiring.
Just before switching to pwm mode, bulk charging current would be at 18.9a (280w/14.8v)... Same as with parallel wiring.
However, as it switches into pwm mode, current would drop to only 8.2a (1x Isc), and amps would taper from there. So if abs charging continued for any significant length of time, there would be significant losses.
JiminDenver wrote:
A MPPT controller switches to PWM mode after float for two reasons. There is no longer the loss with the battery being at a higher voltage and the battery could not accept the additional current anyways. The extra current is still there, just not being used to charge with.
โJan-30-2015 10:57 AM
